Can n e 1 please tell me how to get round this error message in tmpgenc
Write Error Occured At Address 77F83905 of module ' ntdll.dl ' with 00000000
Tryin to convert avi file to svcd
Thx![]()
Results 1 to 10 of 10
I get write errors sometimes when trying to convert from avi files. I can usually fix it by running the file thru virtualdub.
Open it in virtualdub. Change the video to direct stream copy and save the file. Don't know why, but it seems to clean up the avi while still keeping the same codec. Takes about a minute depending on the size of the avi -
saved wav file as outlined in your reply
still get error message as per my first message
n e ides ne 1? -
This works every time:
1) Reboot
2) Uninstall TMPG
3) Reboot
4) Delete old TMPG folder if still present
5) Re-install TMPG
6) Encode....er...EnjoyTo Be, Or, Not To Be, That, Is The Gazorgan Plan -
Do what Rubberman said. Note, he did NOT say to save as wav. Direct stream both audio and video, then save avi.
Sorry. I should have said save as AVI.
I saw it somewhere once. Can't remember where. I think it was somewhere on this web site. -
Thx 4 the help people
Still gettin the same error message when i try to convert my avi files to mpeg 2
have run the files thru virtualdub using direct stream
N e more ideas or am i gonna have to be disappointed newbie
is it xvid..? tempenc doesn't like xvid movies, crashes it every time (for me anyway)...if it is reply 'yes' and i'll tell you how i get round it the easy way...
Don't you guys ever read the forum before you're posting topics ?!!
Go to option in Tmpgenc, go to environmental settings, go to VFapi plugin's
and give directshow the highest priority (number 1) with a right mouseklick on Directshow.
read before you ask ! -
This doesn't always work. When this fails I run it through VirtualDub like I mentioned before.
Although, sometimes increasing the directshow priority works where the Virtualdub solution doesn't.
If these don't work you could always try encoding to a different AVI codec.
TMPGEnc Write Error's of module 'P3Package.dll'
By manicradio in forum Video ConversionReplies: 0Last Post: 29th Dec 2010, 17:55 -
Error -1856: An Unknown error occured
By Tyler2000 in forum Software PlayingReplies: 2Last Post: 27th Oct 2010, 19:55 -
virtualdubmod crashed out of bounds error module divx
By themods in forum Newbie / General discussionsReplies: 24Last Post: 25th Sep 2010, 00:37 -
VirtualDubMod ntdll error.
By tat2jr1 in forum Video ConversionReplies: 10Last Post: 25th Jul 2009, 07:15 -
Access violation in module ntdll.dll
By Blå_Mocka in forum AudioReplies: 3Last Post: 10th Feb 2008, 13:09
