When i Burn an DVD to an DVD-R it does not always play by itself when insert it into a dvd player, does not matter what player.
(they all support DVD-R)
I sometimes have to press play or the menu button.
and sometimes it does not work at all.
but most times it works.
what could be the problem???
What am I doing wrong?
I shrink the dvd9 with dvd shrink and burn it with nero6.
I use UDF1.02.
Burn speed is 4x
My burner is a Sony U10A 4x
PS. How can i post an image, i cannot seems to get the pic. below 16kb.
Greets, Mysterio
It sounds like your players are a little bit fussy about the media - I've come across a few discs which play OK when the DVD player has finally got its focusing sorted out after a couple of reloads.
If you have to press play to make them work occasionally, this is probably reseting the player and making it "look for the disc" again. Try recording the same material onto a different manufacturer's media and see if the problem persists.
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
LG LHB953 not playing burned copies of my DVD's
By SMaldo in forum DVD RippingReplies: 8Last Post: 3rd Jan 2010, 21:43 -
DVD's not playing properly after being burned
By Digger777 in forum Video ConversionReplies: 5Last Post: 25th Sep 2008, 23:52 -
Problem Playing DVD I burned
By hollywoodfussell in forum Newbie / General discussionsReplies: 4Last Post: 8th Sep 2007, 07:46 -
Ripped/burned AVI DivX files not playing in pc or DVD player
By perceptionist in forum DVD RippingReplies: 13Last Post: 4th Jun 2007, 03:55
