recently i haved purchase a TV LEADTEK WINFAST "DELUXE" TV2000XP TV/FM MULTIMEDIA CARD - RETAIL BOX capture card. http://www.newegg.com/app/viewproduct.asp?DEPA=&submit=Go&description=LeadTek
i want to find out how would i be abel to connect my vcr into my computer. the connector come with the retail box. ddidnt' match with my vcd. isn't there any cable that i can buy to connect my vcr into my computer.
thank you
i need answer
wilbasket23,
from the link you provided, it seems as tho your capture card has both a composite and s-video input. One of these will match your VCR. Most likely it will be the composite terminal. That is the one towards the bottom of the capture card. The S-video connector has mulitple pins and requires a special cable. The composite cable is generically a simple stereo type cable. Of course for better capture you would need a better quality cable (shielded helps a lot). Then just connect the video out on the VCR to the same type connector on your capture card. Remember this is just a video capture card. In order to capture the audio you will need to connect the audio out on your VCR to some sound ports on your PC that are either built in or via an add on audio card.
Then launch your favorite capture software and have lots of fun.
Ed
VHS to S Video Capture Help
By bob52 in forum Capturing and VCRReplies: 11Last Post: 2nd Mar 2012, 02:17 -
EP VHS video capture
By Lucky Starr in forum Capturing and VCRReplies: 11Last Post: 27th May 2011, 01:09 -
Trying to capture video from VHS
By JoshGlzBrk in forum Capturing and VCRReplies: 1Last Post: 19th Dec 2009, 22:33 -
Capture VHS Using TV With Built in Video
By JonnyAlpha in forum Capturing and VCRReplies: 6Last Post: 8th Nov 2009, 18:38 -
VHS to DV capture: Component video vs. S-VHS
By vega12 in forum Capturing and VCRReplies: 8Last Post: 19th Feb 2009, 20:42
