Greets, and thanx to the maintainers (this is my 1st post)
I have made a few VCDs successfully using Nero 5.5 and 6.
Now I am trying to make an SVCD (for the higher quality); the
video clip is one of my POV-Ray animations. The SVCDs look ok
when played on my PC, but in my DVD player it has a problem:
* The left-most portion of the image (a narrow sliver, maybe 40 pixels)
is wrapped around to the right-most side of the screen.
* A small square area in the lower-right corner flashes spurious colors
(usually blue or white)
Additional info:
> The MPEG-2 files I've tried have been created by VideoMach,
TMPGEnc25, and Nero, all with the same results.
> The image sizes have all been 480x480 (plus a few with larger
width just to see what happens, but with no change).
> My DVD is a Pioneer 503 (5-disc changer) which is supposed to
support SVCD.
> The test SVCDs from VCDImager work fine, so I think the player
can DO a SVCD, but something MY SVCDs is not right.
If there is any additional info I can give, please let me know. I sure
hope someone can help me out here!
Thanks,
Mark
You could try author and burn with VCDEasy or another SVCD author/burn tool.
Thanks for the reply!
Ok, I tried using TMPGEnc 2.5 to make the MPG file, and
VCDEasy to create the CD image.
VCDEasy could not burn the CD, looks like a driver issue
(I have an R2102 DVD-R/CD-RW in a Toshiba laptop),
so I let Nero burn the image.
This worked without the wrap, but the image quality is
now inferior to what it used to be! I thought TMPGEnc would
most likely do the best job at encoding! But in my clip
(an animation with a planet and stars), the stars are big and
chunky (one is a big square), and the planet details looks
like it has been dithered. In the original creation (using VideoMach
and Nero), it looked better.
I am closer to my goal now, but I'd appreciate any thoughts on
how to improve it further...
Easiest way to flip video horizontally
By bseos in forum EditingReplies: 3Last Post: 18th Oct 2011, 13:27 -
Fixing horizontally stretched video
By robjv1 in forum EditingReplies: 7Last Post: 10th Sep 2010, 02:49 -
White screen at end of trimmed videos - AviDemux 2.5
By BobAchgill in forum EditingReplies: 0Last Post: 6th Aug 2010, 23:12 -
Exporting video is Squished (Horizontally)
By Daniel Arroyo in forum MacReplies: 3Last Post: 22nd Oct 2008, 09:06 -
Vegas Video - Video getting "scrunched" horizontally
By 1320Video in forum EditingReplies: 3Last Post: 16th May 2008, 22:12
