i have a 700 meg avi of episode 4 and i have tried to burn it to a dvd but for some reason the audio gets "unsynced" once burned. and not just by a little, but by a lot. the avi playes fine on my machine, but for some reason when burned to a dvd via DVD Architect, it seems to fall apart. what is the best way to get this file to a dvd. i don't want fancy menus and would settle for just chapter points, but just a dvd would be a great start.
i also happen to own Episode IV A New Hope, so this is not a bootleg.![]()
I'm pretty new at this, but why not try something else to see if you ger better reults. download the free nero 6 trial and give it a whirl.
God bless -
I'm not quite clear on that statment.
It sounds like this is where you converted your AVI to a compliant MPEG2 so you could author it to DVD. This (conversion) may be a trouble area as well as the burning software.Don't give in to DVD2ONE, that leads to the dark side. -
It's always VBR audio. In vdub, save the audio as a WAV. Then when encoding to MPEG2, use the PCM WAV as your audio source.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
what i mean is that when i burn it using dvd architect software.... if fizzles out and does not sound right.Originally Posted by Marco33
thanks for all the other help folks.
there is hope for 3d after all
By aedipuss in forum Newbie / General discussionsReplies: 19Last Post: 18th Mar 2012, 10:21 -
Hope someone can assist me with my process...
By Cralis in forum Newbie / General discussionsReplies: 5Last Post: 5th Mar 2010, 20:41 -
Any hope for this footage?
By wwaag in forum RestorationReplies: 4Last Post: 13th Sep 2009, 14:06 -
Is 480i the best an average Joe can hope for?
By gigantibyte in forum Capturing and VCRReplies: 32Last Post: 10th Feb 2009, 07:49 -
I hope it's true!!!
By zoobie in forum Off topicReplies: 2Last Post: 16th Dec 2008, 00:21
