on all players ? tried IMGTool 0.9 and DVD Decrypter but somehow it is not as good as some players still play errractically and freezing. Any ideas on what I can do ? What about Record Now 4.01 ?
Ideas about what to do? Sure, use quality branded media (TDK, for example), and tell your friends to buy new players.
Nope, I'm not kidding. It isn't the burning software, or the ripping software, it's the *player* that's most likely at fault (assuming it isn't the media) -- this is assuming you know what you're doing and can get the disk to play on *some* player.
No matter what you do there will always be a certain percentage of players that won't play DVDR properly -- the older the player the more likely this is. Just about any player made in the last year or so will play just about all DVDR (not RW) properly, and they are cheap. Getting a new player is the best solution to this problem."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang
Making MPC-HC compatible with more videos
By dandandan in forum Software PlayingReplies: 5Last Post: 27th Jul 2010, 08:37 -
Making sure AVI is compatible with DVD players
By uniks in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2009, 17:31 -
Making videos "for sure" playable in standalone player
By Meagain in forum Video ConversionReplies: 1Last Post: 29th Dec 2008, 16:39 -
Most Universally Playable DVD Authoring Software
By cyberboy in forum Authoring (DVD)Replies: 2Last Post: 25th Aug 2008, 07:19 -
Need simple guide on making AVIs compatible with Xbox360
By sad_muso in forum DVD RippingReplies: 4Last Post: 22nd Aug 2008, 13:12
