ok i have 2 mpegs i wanna put on the same CD-R they are SVCD created with DVD2SVCD and i wanna add a menu thats off the actuall DVD here is a screenshot of the menu as it shows up in DVD Shrink i need to know how to rip it off the DVD and then i wanna add it to my SVCD when i burn it i can choose what one of the 2 i wanna watch by using the menu
well...if you just want still images...you can capture those menus to .jpg using winDVD/powerDVD
then follow these guides:
https://www.videohelp.com/svcdmenun55.htm
https://www.videohelp.com/forum/userguides/84327.php
http://www.doom9.org/index.html?/mpg/tscv.htm -
poopyhead
What guide do you suggest i use
all i wanna do is add the still image of the pictire i showed above showing there is 2 movies to choose from
1. Frosty The Snowman
2. Frosty Returns
That way when i pop the svcd in my standalone i can hit the up or down button on my dvd remote and choose what movie (MPEG) i wanna watch -
if you already use nero to burn your SVCDs, then i would suggest you use nero to make the menus...since all you want are simple still images....
How can I create this very simple menu with Multiavchd?
By alc112 in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Jul 2010, 14:26 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 23:38 -
software to create simple animations.
By cd090580 in forum Newbie / General discussionsReplies: 1Last Post: 6th Jun 2008, 17:29 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36 -
Create new menu to link to existing menu. Possible?
By Noy2014 in forum Authoring (DVD)Replies: 3Last Post: 14th May 2007, 13:22
