Well? Is it?
I know it's a lot faster (if you have a P4, like me) than the beta 12x versions, but is that all (aside from the fixed GOP bug)?
How about MPEG2 quality? Any better? Worse? Right now I am using TMPGEnc 12j and it works like a charm, the MPEG2 quality is fantastic and I have unlimited MPEG2 encoding.
Should I move on, or stick with my 12j? Version 2.00 looks tempting.... I hope they didn't change their MPEG2 30-day MPEG encoding trial period algorithm, because that is really easy to bypass.
Anyone want to share their thoughts on Version 2.00?
AP Enterprises Ltd. -
Okay - I just downloaded it, and it is basically the same thing... The 30-day limit is still there, but fortuately, it is the same "type" as the beta versions. So I again now have unlimited MPEG2 encoding... Speed is a tad bit faster... I wish VCDHelp.com would make a comparison because I can't really see a difference in visual quality.
I tried it on a very small 1 min clip, comparing 12j and 2.00. I loaded a 352x576 clip and encoded with default svcd pal template. 2.00 was slightly faster. There was a resize on the clip so that might have affected the apparent performance difference. I don't see that it's so much faster as to get too excited over, but I at least should say that I appreciate TMPGenc for making such a high quality encoder available. If they do start charging, then I probably would buy from them.
I echo the suggestion that vcdhelp adds it to their comparison. There are a few new encoders based on the Ligos Gomotion technology, so a comp with that would be cool, like Ulead MSP 6.5 or Power VCR(I believe).
Matt
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 22:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
