I am trying to create a VCD of an Italian movie. There is an audio track with English dubbing. I used Smartripper to create the VOB files, and the vobinfo.txt file says that the 3rd track is the English audio.
I'm using dvd2avi (version 1.74), and in the audio option selecting track 3. The wav file is never created. I've tried a few different things, and the only time I can get a wav file is if I leave the audio option at Track 1, and then it obviously comes out in Italian.
Any ideas?
Since you ripped the DVD with SmartRipper, you can use the *.lst file with vob2audio and try that. It has a nice GUI and it should show you all 3 languages corresponding and let you rip it to WAV or MP3 (your choice).
Make sure in SmartRipper than you enabled stream processing, and either choose all languages or the one you want (ie. re-rip and check).
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 24th Jan 2011, 00:28 -
How to choose audio track in avi file with two audio tracks
By newnews in forum AudioReplies: 3Last Post: 26th Oct 2010, 06:26 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
--> Adding Audio CD Tracks to DVD audio ? <--
By MJPEG guy in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 17:45
