Is there another programm that works like dvdlab
but can make the chapters motion .. so not only the background
DVD-Lab can create motion chapters, you have to supply the video.
Some of the cookie cutter authoring programs have auto motion menus, but then you lose a lot of options and customization with those as well. -
In fact, what I do, is a combination of things.
I use Sonic MyDVD to create the motion menu. This is a sorta brain-dead process, since it doesn't seem to let you specify chapters... so I load the same video once for each chapter. I then simulate the menu, which creates a motion menu in the file system. Then I drag that onto a menu in DVD-Lab, and then add frames around the locations where the individual clips are. Voila! -
Yep, these guys are right. Another way of looking at it: since you want another program that can make motion chapter menus, just use Premiere or After Effects (or Vegas Video or a hundred other programs). Make your motion menus and then use them in DVDLab.
You'll get the best of all worlds -- the best DVD authoring product along with a good editor or special effects engine (indeed, Adobe Encore, the $500 DVD authoring solution, recommends using After Effects for your motion menus)."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
Ulead DVD Workshop features motion menu support.Originally Posted by Dj_Rainaldo
Here is a sample tutorial for how to do a motion menu:
http://www.ulead.com/learning/dws/dws_02_1.htm
Jerry Jones
http://www.jonesgroup.net -
Jeff Muller wrote:
Jeff, how about a short guide on that.use Sonic MyDVD to create the motion menu. This is a sorta brain-dead process, since it doesn't seem to let you specify chapters... so I load the same video once for each chapter. I then simulate the menu, which creates a motion menu in the file system. Then I drag that onto a menu in DVD-Lab, and then add frames around the locations where the individual clips are. Voila!
how to rearrange the movies in dvdlab
By sumeshkri in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2010, 07:18 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 09:42 -
DVDLab Audio Playback
By alhall in forum Authoring (DVD)Replies: 1Last Post: 26th May 2008, 10:00 -
DVDlab Compared with TDA
By loster in forum Authoring (DVD)Replies: 7Last Post: 30th Dec 2007, 20:34 -
Is there any other software like dvdlab?
By anfield7 in forum Newbie / General discussionsReplies: 7Last Post: 1st Oct 2007, 05:55
