help with puting a movie on a cd and watching it in a dvd player
Hi guys i got a movie and when i open it its got the files CDI EXT MPEGAV SEGMENT and VCD can anyone tell me how i can put the files onto a cd and watch them in my dvd player
Thank you
What do you mean with 'open it'.
What you list as files are usualy Folders on a VCD.
If so and they are mostly filled with files (SEGMENT can be empty) you just need to burn them plain to a cd. Voila - its a VCD. If your DVD player plays VCD, you're done.
I'm not sure if SVCD has the same structure. So check also if your DVD can handle that as well.
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 12:07 -
compare movies, find insertions in one movie relative to another movie
By beroal in forum Newbie / General discussionsReplies: 0Last Post: 18th Jan 2012, 23:11 -
Puting a slide show and a video separately onto the same DVD
By coastie in forum Authoring (DVD)Replies: 3Last Post: 10th Sep 2011, 04:44 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2011, 23:16 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 11:33
