I downloaded VideoStudio last night and tried to capture some video, but got an error message that the capture device was not found/unusable.
I'm able to capture with VirtualVCR, so I believe everything is installed and working properly.
Anybody else having this problem? If not, what drivers are you using?
Thanks.
I have the Hauppauge WinTV-PVR-250 PCI card and can not capture with any other capture program other then the WinTV2000 capture software that came with the card. I have downloaded the latest drivers and codecs from Hauppauge with the same results. Although I have not tried Virtual Dub, believe me I have tried them all. I find the WinTV2000 capture very good with many settings for DVD. I then have to import the capture into Studio, DVD Movie Factory, etc. and go from there.
lennyt that not ture there SageRecoder, SageTV, SnapStream, WinTVCap, etc, etc.
But min other tools where not build to support MPEG streaming. -
The apps your trying to run like Virtual Dub, DVD Movie Factory, etc and min other 3rdparty tools only support YUV/RGB streaming aka AVI which only reg TV card has which dosen't do any Hardware Encoding like WinTV-PVR 250/350.
Hauppauge 1212 HD PVR & VirtualDub
By MakiManPR in forum Capturing and VCRReplies: 3Last Post: 23rd Oct 2011, 12:31 -
Questions about Hauppauge 1196 WinTV HVR-1250 PCI Express Card
By Wizard23 in forum Capturing and VCRReplies: 15Last Post: 25th Feb 2011, 16:22 -
Easycap & Ulead VideoStudio Movie Wizard Step Two
By kiwisue in forum Capturing and VCRReplies: 0Last Post: 23rd May 2009, 05:14 -
VideoStudio 9 & 10: No Sound from HDD Camera
By markannab in forum EditingReplies: 1Last Post: 1st Dec 2008, 03:52 -
H.264 TS Cutter & hauppauge HD PVR
By unplug in forum EditingReplies: 0Last Post: 4th Oct 2008, 23:40
