Results 1 to 21 of 21
  1. I have encoded a file using avisynth to frameserve into CCE 2.64 and 2.5 (thought this might have been the problem) but the file plays fine then goes all wobbly/distorted when there is a scene change or high movement or just cause it feels like it. I Have tried encoding the file without avisytnh and the file plays back beautifully...I did have 2.08 installed I removed it to put 2.5 I beleive I have conflict issues possbly not uninstalling avisyth correctly. I went in and deleted the avisynth.dll and reinstalled ..problem still occured. I love avisynth and has never cuase me a problem like this before ...suggestions guys oh yeah i did use the unistall.reg etc...
    How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
    If you like Tekno download one of my tracks
    www.users.bigpond.net.au/thefox149
  2. post script
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
  3. Iam writing this of the top of my head as I am at work...it is only a simple one
    AviSource("E:Capture.avi")
    Trim=(1080,255000)
    Crop(7,8,348,566)I am just putting these in as I can't really remember
    BicubicREsize(352,576,0.33,0.33)
    It is a simple script ...I have a definte avisynth problem as I frameserved with vdub...no probs....can someone tell me how to completely remove avisynth and which version I should use...I like the speed of 2.5 but is it worth the problems
  4. Yea it's pretty basic, Id try a LanczosResize(352,576). If it doesnt work, you might have problems w/ conflicting AVISynth's. I use 2.52 and I'm happy with it, but Im not sure on a good way to insure a clean uninstall.
    I'd also suggest checking out doom9's forums, as there are lots of AVISynth guru's over there.
    Ejoc's CVD Page:
    DVD:
    Capture:
  5. Thanks I wonder if any of the experienced users out there have had this problem. I will post a screen shot when I get a chance
  6. I believe it maybe a conflict with the resize....i am really at wits end here...and I can't post on doom9 until I have been registered for 5 days.....
    Is there a reistery key that I have to remove...
  7. Try opening the script with windows media player. Just for the halibit.
    Also try small clips through CCE omiting each seperat line one by one till the bad line shows it's face.
    Don't give in to DVD2ONE, that leads to the dark side.
  8. Good Idea Marco I will get on it...now that is thinking.....
  9. I have isolated the problem. Anytime I do a resize I get this problem. I have tried to use an external plugin (simple REsize plugin for 2.52) but still getting the probelm...this only happens when I am trying to resize. I have also tried LanczosResize still no joy...
    Any Ideas....I have resinstalled etc .....even when I try to go back to 2.08 this problem occurs..I resinstalled my os (ghost) installed 2.5 clean and it still happens...am I the only one having this problem ...is it a known bug...on celerons maybe ....help!!!...oh I might add I tried to resize with vdub and the same errors occurred....
  10. Sounds to me like you are sure it's CCE.
    Have you tried FitCD to write the script for you?
    For fun... here's mine.
    BicubicResize(720,240,0,0.6,0,0,720,240).Weave()
    and yours...
    Upercase E... maybe?
  11. the same thing occurs in Tmpgenc....I know it's the resize function...it is an interlaced source usually i deinterlace (I haven't tried this) it is the strangest problem i have had ...I tried also to convert to YUY2 co.orspace just in case it didn't like the avi.....but noy joy.....
  12. I want completely unstall avisynth ....how ??? besides the add/remove what else should i be doing??
  13. I have just realised that the ghost i released also contains Avisynth 2.5...which came with DVD2SVCD if i remeber correctly i was mucking around with Avisynth 2.08 & 2.52 in the install.......I beleive i will have to (provided i can't find an answer) is release my clean ghost with no programs on it just xp....Come on guys ....surely one of you can help!!! I am gettting desperate.
  14. I have been reading the forums on Doom9 and there maybe a problem with resize on celeron machines in 2.5....anyone using a celeron and getting this problem?
  15. Try a search (on this site) with Celeron & AVsyth as key words.
  16. I worked it out. When I intially capped the vid I uncheck force YUY2 output.
    I did a test cap with this ticked ...no problems....However I can't view the file in Vdub as it says error decompressing video frame.....but if i load it up in an avs script ...no problem....how can i get around this???
    Aug 2002
    With avisynth 2.5 and when encoding with CCE I have to add following line in the end of my script
    converttoyuy2()
    Maybe this is your problem?
    http://www.avisynth.org/index.php?page=Section+1%3A+About+AviSynth#q1.10
    Ronny
  18. yeap..it has been a long drawn out headache to get here.....Big thanks to marco and know ronnylov.....
    Should i force the yuy2 out put i hear there are advantages
  19. Well i thought that was the problem when in fact it is not....
    This seems to only happen when i frameserve (even vdub) for a resize....
    I have reinstalled the aviclient that comes with vdub i am really stumped can anybody help...why has frameservering forsaken me......To convert the file i have to go back to tmpenc and let it take care of clipping and resizeing.....SLOW as but at least it's getting done.....another thing is i tried to fooce this distortion wobblyness on a test avi ...but it didn't do it...could size of the file have something to do with it or even the trim function in avs....so many variables...
  20. My next guess is that i have conflicts with and video editing or video application software...does anyone know if Avisynth conflicts with any other program
  21. Hooray I have worked it out.......Avisynth conflicts with ReelDVD....I uninstalled reel and bang it stops working....Does anyone know if this is a known problem!!! I really don't care i am so happy
