can anyone help me with this problem?
i need to make a cd, contain a video cd and an audio that burn in one cd. i have make it one, but i can't play the vcd on vcd player. i only get audio cd played.
i've been met this kind of cd. my friend's cd.
i want to make this cd. can anybody would help me with this? please..
is that even possible???
i know there's a hybrid audio CD/DATA CD.....i guess you can do that...make the audio CD and then burn the .mpg videos you have in the DATA portion. i'm not sure you can have both an audio and VCD on the same disc.
edit: sorry...i'm wrong...my bad...check this guide out: https://www.videohelp.com/forum/userguides/113432.php
How to convert PCM audio track inside M2TS file
By majouz in forum Software PlayingReplies: 1Last Post: 20th Jun 2011, 15:24 -
What's the best format and resolution for LCD TV or HDTV from DVD and VCD.
By newbievideohelp in forum Video ConversionReplies: 6Last Post: 6th Nov 2009, 14:23 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
No audio decompressor could be found to decompress the source audio format.
By rocky12 in forum AudioReplies: 3Last Post: 1st Sep 2008, 01:59 -
Problem loading AC-3 audio (inside MPEG) in Premiere
By irving in forum EditingReplies: 2Last Post: 23rd May 2007, 10:25
