I have 8 avi files that i'm trying to author in ulead mf2 but the total file size of all the videos is 5.0gb is there anything that can be done to compress the files just a bit to fit them on one dvd-r. I thought about cutting off extra bits that i didn't need but there still to big, would something like dvd2one help or am i jusy out of luck.
thanks in advance.
I would author the DVD as is, then run the output files through DVD2one (about $40) or ShrinkDVD (Free) to compress to fit on a single DVD
hi jonez, I've never tried to use dmf for converting avi into mpg, don't know how much freedom you have in managing bitrate.
I suggest you to use a specific encoder (like tmpgenc) and play with bitrate until you find the one that fit your needs.
it's bitrate that fits the disks, not how long the movies last.
turning multiple avi files to dvd
By videodude1966 in forum Video ConversionReplies: 1Last Post: 23rd Dec 2010, 19:32 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
Multiple AVI file for one DVD
By tim_ver in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jan 2009, 04:45 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 03:28 -
Multiple AVI's to DVD ????
By paulwilko in forum Authoring (DVD)Replies: 3Last Post: 5th Oct 2007, 05:30
