I have noticed this form doesn't work right anymore when I use Safari. It started about a week ago. Works fine in Mozzila or IE, but I get the following issues only in safari:
Post to a poll, screen doesnt refresh showing that I voted.
Can't post more than one reply to any given thread. If I do I get an error screen saying I already made the post, even if it's a new reply.
Topics don't update on home page unless I specificly hit refresh.
I haven't changed anything on my end...
There's a button on the upper right side of Safari. It's a picture of a bug. If you hit that, you can report to apple exactly what happened, and at what website. The developers will check it out, and sometime in the future, Safari will be an even better program!
They've gotta know about it to do anything about it!-kamikaze -
They already know about this problem. Safair 1.0 has a cache problem. The only way to fix it right now is to re-install a beta or disable the cache using Safari Extender. If you look in the feedback forum, Kaicherry brought the same problem up about a month ago.
The only problem I noticed is that once you post a remark, and it brings you to your post, if you click on the link to go back to the forum menu, it wont be updated. Pushing refresh will reload the forum menu and you can see your new post.
Other than that, and the fact that the COMPUTER DETAILS doesnt pop up in the text window like it does on a PC, it works for the most part. -
just disable your cache -- "get info" on /Users/you/Library/Caches/Safari/ and switch permission to "read-only" -- after you manually empty (trash) its contents, of course.
it's an option, anyway -- i prefer not using safari's cache.
XviD4PSP & Avidemux Doesn't work for me anymore.
By The_Jelly in forum Newbie / General discussionsReplies: 15Last Post: 14th Mar 2012, 09:05 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 19:07 -
dv capture and playback doesn't work anymore (except in quicktime)
By richardlode in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 15th Jun 2008, 02:22 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 06:58 -
Philips DVDR7310H: search (Guide Plus) doesn't work anymore
By Monco in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Aug 2007, 13:05
