ok, I tried to make an scvd with nero 6, but it kept freezing after it finished encoding the file but before it burned it to an 80min cdr. I think now the problem was the encoded file would've been too big. but regardless.
I just used tmpgenc and got the divx file encoded to an mpg. my question is when I burn it to cdr using nero, do I burn it as a video cd choosing the svcd option or a data cd? I'm thinking probably data, but I want to make sure and not waste another 3+ hours on nero.
nope....
you need to use nero's SVCD template to author your .mpg as a SVCD. most dvd players will not read raw .mpg files burned as DATA CD. if you do, most likely only your PC will play the .mpg file.
most DVD players require the file/disc structure of authored (S)VCD discs to play those .mpg files.
max 795 MB .mpg file can fit on 1 80 min CD-R. -
nero will recognize it as an mpg and not try to encode it again tho, right? it took forever to do the encoding before
don't ever let nero do the encoding...it SUPREMELY SUCKS at it.
as long as your .mpg file is a compliant SVCD, then it should be fine. if nero bitches, just uncheck "make standard, compliant disc" -
yeah, tmpgenc did it a lot faster too. ok, thank you for the help, I appreciate it!
ok, I just burned it and tried it on my standalone dvd player and it didn't work. it kept saying no disc. I have an apex 1100w, and according to the compatibility chart that should play scvds. I looked on the cdr from the d drive, and it has five folders. I didn't create a menu when I used nero. should I have done that? or does that not matter, and the dvd player should've been able to see the mpg in the ext folder? I'm using nero 6.0 btw.
do you have winDVD or powerDVD installed on your computer???
if you do, try to play your SVCD in your PC using either of those 2 programs.
btw, did you uncheck "make standard, compliant disc"?? try leaving it checked if at all possible.
also, how fast you burn?? try limiting to 4X and c if it helps.
one last thing, try your SVCD on a friend's DVD player and c if it works.
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 12:59 -
question about how to burn Nero Image
By jimdagys in forum DVD RippingReplies: 5Last Post: 4th Sep 2010, 12:06 -
Nero Recode question
By wulf109 in forum Video ConversionReplies: 1Last Post: 4th Aug 2009, 08:55 -
nero 8 question
By m-man in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2009, 14:38 -
Nero 8 transcoding question...
By RaGuSNY in forum Video ConversionReplies: 3Last Post: 4th Nov 2007, 15:23
