If you have a high quality 2-CD SVCD template for TMPG that you would to share, please email me at surferr_1@yahoo.com. Thanks in advance.
surferr
When you say 2 CDs it really depends on the runtime of your source. If you want to generate two SVCDs using the normal template use the 'source range' option to encode:
http://www.vcdhelp.com/DVDConversionGuidev1.3/dvdtovcd2.html#TMPGEnc
If you want to make an xSVCD where each part of the movie fills up the whole CDR try this:
1) Click on Tools | Bitrate calculators (the vcdhelp.com one is fine, they're really all the same). Enter all your info. This will give you a video bitrate to use.
2) Run TMPGenc, load the SVCD or VCD template. Then load the unlock template (../templates/extras) this wil unlock all the greyed out portions of the standard template.
Load your source as normal.
3) Click on settings. Set motion search to high, and under encode choose either CBR or 2pass VBR.
CBR - constant bitrate. Just enter the number from the calculator
2pass VBR - variable bitrate. Will make 2passes (this will double the encode time). max=dvd players max, ave=calculator, min=(calculator-300~500). This will give a better encode, but unless your source is DVD or high quaility, just use CBR to save time.
If necessary click on the audio tab and set the bitrate to what you used in the calculator.
4) Setup source range (see link above).
2CD Quality Encoding.
By scott274 in forum Video ConversionReplies: 5Last Post: 17th Dec 2009, 19:05 -
DVD on Sony Walkman X, "SP" template but high bit rate
By dch888 in forum DVD RippingReplies: 1Last Post: 6th Dec 2009, 16:19 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38
