Hi People,
I'm in the process of capturing my sister's wedding video so as to author onto a DVD and was wanting an idea as to what you all consider is an acceptable # of dropped frames.
So far after an hour of capturing my system has dropped 10 frames (spread out over the hour). Now i realise thats not even half a second of footage (I'm using PAL) but would that be noticeable on the finished product.
FYI - I'm using AVI_IO and am capturing with Huffy at 720x576 on a PIII 1.3GHz Celeron.
Fingers crossed I don't drop too many more frames.
cheers,
cliffo
If the 10 frames dropped all at once then it would be noticeable but over the whole hour well thats great you won't notice anything. I set myself a guide of 1 frame every 5mins I consider excellent...but it also depends on the video tape I have found old tapes drop more frames and newer ones hardly any at all ...there are alot of factors as to why your system drops frames ...but 10 frames in an hours would not be able to tell.
How long could we maintain? I wondered. How long until one of us starts raving and jabbering at this boy? What will he think then?
If you like Tekno download one of my tracks
www.users.bigpond.net.au/thefox149 -
I wouldn't worry about it unless you either saw some big glitch in the video, or the audio started to get out of sync.
depending on how I capture, I usually drop around 8 frames an hour. I have yet to see an actual effect in the finished video.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Thanks guys,
I ended up with only 14 dropped frames for a 2 hour capture and i couldn't notice any glitches in the video..i'm in the process of converting to DVD compliant MPEG2....(goes off to watch the clock...)
cherrs,
cliffo
AverMedia HD DVR - Frame drops in live playback
By Anonanon in forum Capturing and VCRReplies: 3Last Post: 1st Mar 2012, 01:11 -
Joining 2 TS streams produce glitch and frame drops
By arminio in forum DVB / IPTVReplies: 8Last Post: 7th Jun 2011, 02:30 -
pad , frame number for editing
By smartel in forum Newbie / General discussionsReplies: 5Last Post: 7th May 2011, 00:44 -
ffmpeg Number of stream maps must match number of output streams
By tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 06:20 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26
