    Apr 2003
    australia
    Ok- just bought the Pioneer A06 and installed the software that came with it- It came with nero express- my problem is that there dosen't seem to be any option to burn Dvd's on it. It has an option to do VCD's and SVCD's under audio and video in it's menu- but no dvd option. And when I try to load a dvd file into the menu as a data file it shows I am way over in size- so its assuming that I am using a CDR disc. If I can't burn DVD's with nero express, why do they bother even packaging it with the burner?. I have other burning software, but none of them recognise the Pioneer drive, so do I have to get another program to do the job, or is it hiding away in a sub-menu.
  2. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    That is the only program I use to burn DVD's with. At the top of the main menu, it should ask you WHICH RECORDER WOULD YOU LIKE TO USE. Click the down arrow and choose your DVD burner. Then choose to burn a DVD Video and highlight everything that you would like to burn and click ADD and burn your DVD.
    GOOD LUCK,
    SLICK RICK
    Nobody likes a bunch of yackity-yack.
    Apr 2003
    australia
    Thanks for the quick answer. I am going on lunch soon so I will go and try that and see if I can get it working.
  4. Member SLICK RICK's Avatar
    Mar 2003
    Post your results and let us know how it turned out.
    SLICK RICK
    Apr 2003
    australia
    Well thanks to rick, I got the program working!. I burned the movie on to a dvd-rw, stuck it into the dvd player, and WOW. The Thing works like a dream, even with the compression level set up to seven with dvdshrink. My first dvd- I'm really happy!
  6. Thank you for the info. Nero Express was included when I bought my TDK DVD+R burner and I was a little upset when I didn't see the option to burn a DVD.
  7. Member ebenton's Avatar
    Jul 2003
    The WINDY state (Florida)
    Nero Express and Nero are pretty smart programs. If you tell it you are going to be using a CD burner, it won't present you with the option of burning a DVD.
    It always pays to be smarter than the equipment you're trying to operate.
