I have never been happy with TMPGenc's audio. So I have been on the look for a fix. I discovered tooLAME but can't get TMPGenc to accept it. I get this message "tooLAME.exe can't be used as external encoder" Can I get some help on the settings needed.
Thanks in advance,
JellyMan
Open TMPGenc, click on Option, Environmental Setting, Enternal Tool Tab. Click on Layer 2 and Browse to find Toolame.exe. When you encode your next file TMPGEnc will call toolame.
<font size=-1>[ This Message was edited by: Lamont Cranston on 2001-09-29 12:02:26 ]</font> -
I tried that and it still gave me the same message. Do I need another version of tooLAME or TMPGEnc or am I just doing something wrong?
The version of tooLAME here: -
http://www.flexion.org/audio/toolame/
works for me.
If this is the version you are trying to use it may be a TMPGEnc version issue. What one do you use ?
jr -
I am Using TMPGEnc V.12e.
I see there are many versions out. which is considered the best? -
Downloaded TMPGEnc v.2.00 tooLAME worked with this version and audio is much improved. thanks for the help.
TMPGEnc for HD to SD conversion?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 20Last Post: 14th Oct 2011, 16:37 -
TMPGenc TS FPS Conversion
By leftofcool in forum Newbie / General discussionsReplies: 4Last Post: 6th Sep 2008, 07:39 -
TMPGEnc problems with RMVB -> Mpeg2 conversion
By rebel316 in forum Video ConversionReplies: 2Last Post: 7th Aug 2007, 04:33 -
TMPGEnc Conversion 15hrs remain?!
By Squid_uk in forum Newbie / General discussionsReplies: 35Last Post: 1st Jun 2007, 13:01 -
TMPGenc audio delay after conversion
By Shadowofthedarkgod in forum Newbie / General discussionsReplies: 3Last Post: 23rd May 2007, 12:30
