Basically i have some divx movies with very low fps rates. Because ffmpegx only has 3 settings for fps i cannot match up my audio with my video when trying to convert the dixv avi to either mpg1 or mpg2. Please someone help me fiqure out how i can get a divx avi file on either a vcd or dvd with the sound in sync. Some of my toubled outcomes are a regular sound but very fast moving video. Ive been reading the forum and i cant find anything about changin the source files fps...or finding someway for ffmpegx to match it.
Thanks!
~GoodPhun
GoodPhunGuest
I am not sure I can be of any help. But I have
been fighting similar problems and came up with a
solution. But let me make sure I understand what you
are saying.
You have an AVI file.
Does the avi file play in synch?
The frame rate is low. How low? 2 frames per second?
You want to make an mpeg-2 with 29.97 frames per second.
You would like the sound to be in synch.
Have you tried frameserving TMPGEnc with AVISynth?
Tell the frameserver the exact frame rate:
AssumeFPS(28.0365419)
or whatever your actual frame rate is. I quote:
==================from the manual
The AssumeFPS filter changes the frame rate without changing the frame count (causing the video to play faster or slower). It only sets the framerate-parameter. If sync_audio (which is false by default) is true, it also changes the audio sample rate to match the duration of the video, the pitch of the resulting audio gets shifted.
Depending on your particular case, this may or may not be
suitable. Maybe this would be better:
===========================from the manual
ConvertFPS [yuy2]
ConvertFPS(clip clip, float new_rate [,int zone, int vbi])
ConvertFPS() is a video filter for AviSynth. It is available as of AviSynth 1.0b7.
The filter attempts to convert the frame rate of clip to new_rate without dropping or inserting frames, providing a smooth conversion with results similar to those of standalone converter boxes. The output will have (almost) the same duration as clip, but the number of frames will change proportional to the ratio of target and source frame rates.
GoodPhunGuest
Thanks for your post but I am using a mac so i dont think this really helps me. Just to answer some of your questions though....Yes, i have an avi file that will play synchronously with sound. I am trying to change the current fps of that file (about 14-15 fps) to a NTSC fps rate (29.75 or something like that...what ever was said above). If this can maybe help someone else solve my problem that would be HUGE. Thanks again.
Guest
My suggestion would be to export the file to a lossless or near lossless codec in QT Pro at the framerate you want. This will require considerable diskspace, depending on the length of your file. If your original rate is, say, 15, you might want to go for PAL 25 so at least you won't be doubling the number of frames.
Export audio as .wav and add later. You can then encode the .mov with ffmpegX, if it decides to accept the file.
I have had good luck using Motion JPEG A (not B), but several times I have decided to change a setting, stopped the encode, and suddenly I get error messages.
HandBrake Low FPS
By Guess Who in forum Blu-ray RippingReplies: 6Last Post: 17th Oct 2011, 12:27 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 23:42 -
Low fps
By dylanvega123 in forum Video ConversionReplies: 8Last Post: 15th Jul 2010, 04:47 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17 -
Vista64 playing wow with low fps
By johns0 in forum ComputerReplies: 13Last Post: 28th May 2007, 20:57
