I have recorded numerous programs and the audio is perfect when I record and even after I edit out the commercials, it is still in sync, but once I play it on my dvd player, eventually, it starts to look like a bad kung fu movie. I am wondering if it is the software, media, or hardware which is causing my problem.
System
Win 98SE
AMD 1.2
512 SDRAM
40 GB hard drive(10GB free)
Powervcr II 3.0 (Advanced profile vcd ntsc)
APEX 2500 dvd player.
TIA
Kevin H. Bradford
What editing software do you use? Sounds more likely to be a software issue than a hardware one
To me it sounds like hardware. Does it play all the way through on your PC? If so it's your DVD player, or it could be the media doesn't work well with that particular player. Apex players IMO are poor. I had one that would freeze up right in the middle of a movie all the time! I hated that thing.
To answer Sugar, I use PowerVCR to edit also. To Thayne, it plays all the way through on the computer. I make sure to check it. Now, if I run it tmpgenc, it seems to work. Just will have to run more tests.
Kevin H. Bradford -
Have you tried changing your media ?, burning speed ?. Do you get the same results on a different dvd player ?.
Audio Sync issue?
By tb582 in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2011, 11:25 -
Audio sync issue
By Nightshiver in forum AudioReplies: 10Last Post: 2nd May 2008, 18:37 -
Audio sync issue even when dynamically resampling audio
By purpleman in forum Capturing and VCRReplies: 4Last Post: 19th Mar 2008, 10:18 -
Audio sync issue with
By 123fish123 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2007, 17:54 -
Audio out of Sync Issue.
By DSMKilla in forum Capturing and VCRReplies: 7Last Post: 17th May 2007, 00:27
