you guys are pros, me I'm just starting to try and use this so I appreciate all newbie help.
1) I have downloaded mpg files. Out of 11, only two will drag into Toast, and convert fine into VCD.The ones that don't work it says "Please use the VCD option in your MPEG enoder/multiplexer" Why is this?
2) How do I configure ffmpegX 0.0.7c to allow toast to accept them?
3) (How) can I cofigure avi, mov and wmv files to be burned to VCD
4) If you could word this in the simplist way possible, that would be great. I have tried all day to get this to work with no luck whatsoever. Thanks guys/girls!
holeeparsnipGuest
It means your MPEG file is not VCD compliant and so it is not accepted by Toast.Originally Posted by holeeparsnip
Use version 0.0.7d. Select the "Tools" tab, select your mpg file in the first Browse.. field, select "Author as VCD" and click "Author". The resulting .bin file should be accepted by Toast in VCD mode, though since it is not compliant some DVD players will not play it.Originally Posted by holeeparsnip
Choose the VCD preset and encode them.Originally Posted by holeeparsnip
holieparsnipGuest
Wow, It is that easy. I was reading some other post using different programs to convert and I was attempting to encode instead of using Author. Thank you very much. I'm a beer rep for a Microbrewery in real life , so if you ever need a beer in Toronto, Cheers!
-Nathan
holierparsnipGuest
Nothing in this world is that easy!
Well, I converted the files to vcd and threw the .bin in the toast window and....No, It's not that easy.
Most of the 70% mpg I author will only read up to 1.5 mbs instead the 111.5 it should be for a 12 minute show (It takes half a second then says it is "Finished").
Also when I put the ones that are the proper size in toast, They do not seperate and just pile up as one file, and when I make make a VCD it does not work, and when I hit Select in the VCD burn screen it does not show any files.
Can I re Author files as mpeg and get them to work in toast?
any suggestions to what I am not doing right would be more than greatly appreciated.
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 21:20 -
Vegas 10: Mid-project cross-fade (with sanity)?
By Ander in forum EditingReplies: 0Last Post: 22nd Jan 2011, 04:05 -
Lost MPG thumbnails
By terrypin in forum Newbie / General discussionsReplies: 7Last Post: 12th Oct 2009, 02:54 -
movie to mpg for dvd by toast too large; "keep in" been ignored
By jboyd in forum ffmpegX general discussionReplies: 2Last Post: 11th Oct 2008, 14:26 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08
