Please help me!!!![]()
I have an ongoing problem that when i convert SOME ( about 1/3 ) DivX or XviD films the audio is ever so slightly out of sync, the difference may be as little as 1/10 of a second but it makes it look odd on the lips.
I do the same to each file > extract the audio with Nandub ( doesnt always extract as a .wav ), > convert 23.976 to 25FPS with a besweet batch file, Finally i encode at a CBR with TMPGE, i have 2 movies, both are DivX 3 films, one ends up in sync the other not, any ideas appreciated, could it be one is 44100Kbps and the other 48000Kbps??
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14
