Results 1 to 9 of 9
  1. Hey
    Im trying to backup one of my dvd's for the first time with 'dvd shrink'. I had to put the extras which where on the dvd to 'still pictures' to make it fit onto one dvdr. I didnt change anything to do with the menus or the main movie. I pressed 'backup' and im left with a lot of vob files in the folder i specified them to go to.
    What do i do with the vob files? How do i get them onto a dvdr disk so I can make a working backup of my dvd that will play in my dvd player?
    Thanks in advaced
  2. Did you check the guides? https://www.videohelp.com/guides
    Jul 2003
    Florida
    Create a VIDEO_TS and an AUDIO_TS folder and copy all of those files that DVDShrink created into the VIDEO_TS folder and burn with RecordNow Max or I believe NERO will do it as well. Test on a DVD-RW first.
    "Wanting people to listen, you can't just tap them on the shoulder anymore.
    You have to hit them with a sledgehammer,
    and then you'll notice you've got their strict attention."
    -John Doe in Se7en
  4. I wrote a tool AutoShrink that will automate the burning process using Imgtool...
    Check out this site.
    http://www.mrbass.org/dvdshrink/
  5. Member ebenton's Avatar
    Jul 2003
    The WINDY state (Florida)
    If you have Nero Express, you can just drag all of the files into Nero Express, and it will take care of all the file arrangement and burn the disk. I have done this many times after using DVDShrink, and so far so good.
  6. Thanks for the help
    Ill use nero express.
    I chose 'dvd video'. Is there any settings i should change on the tabs?
    And will this work on all dvd players? Cheers
  7. I had the same problem at first. Chances are you did not re-author to strip out just the movie.
  8. Originally Posted by werewolf_02
    no need to change any settings...you may wanna select your burn speed....
    https://www.videohelp.com/dvdplayers check out if your dvd player plays them.
