Im converting a xvid movie to svcd with TMPGenc and the audio extracted to wave by virtudub.
The problems lies in when i have encoded the movie and it makes strange chops certain places in the movie (its not the source that chops)
My settings are:
CBR Constant bitrate: 990
Top Field A
Non Interlace
NTSC Film 23,9 fps
I can say that setting motion search to highest quality removed some chops and setting the bitrate to around 2000 eliminates them completely - but the file is way to large then!¨
Hope somebody can help me
What is the orignal framerate of the file ?, have you stayed true to this ?.
Is this problem occuring only when you reach very dark scenes in the Movie
If so check this topic and the resolution.
https://www.videohelp.com/forum/viewtopic.php?p=588406#588406
If it is happening every couple of seconds it sounds like the Movie is 25 fps but NTSC is 23.9
choppy avchd
By jdcallahan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 27th Feb 2009, 15:04 -
Help With Choppy DVD
By hgsouth in forum Authoring (DVD)Replies: 7Last Post: 13th Apr 2008, 00:18 -
Choppy Result
By darkdog in forum ffmpegX general discussionReplies: 1Last Post: 22nd Mar 2008, 23:32 -
DVD is choppy!
By ronorkis in forum Authoring (DVD)Replies: 2Last Post: 11th Dec 2007, 22:56 -
SVCD converted movie with choppy playback at the end on stand-alone player
By supernano in forum Video ConversionReplies: 0Last Post: 27th Oct 2007, 11:10
