Actually it's not THAT bad..
But after running a SVCD file through TMPGEncPlus, the finished DVD file's sound is "tinny" [for lack of a better word]. It's not TERRIBLE...but it doesn't resemble the source file.
Is there any way to fix this?
Thanks for all the help guys..sorry for being such a n00b...
SVCD n00bGuest
If they have the extention .m2v then you have no sound cause that is only the video file. tmpgenc should also made you a .mp2 file. just mux those with tmgenc (menu file-> option mpeg tools). which i suggested here
BTW: If you reencoded anything it will never be as good as the source cause you're reencoding. -
Guest
I saw that post. But these files are .m2v and have both video AND audio. I haven't muxed anything. Once I do though, that's when I get the two files. 1 video and the audio that doesn't sound that good..
But, I supose you're right...anything reencoded will never be as good as the source..
Perhaps..I could rip the audio with an AUDIO only prog then mux those together like you suggested..?
Thanks for your help though. I DO appreciate it. [even though I feel like i'm running in circles..] -
if this IS the case, just rename them to *.mpg files. I would check first however by installing AVICodec and confirming that they are in fact MPEG program streams(video & audio streams)But these files are .m2v and have both video AND audio
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Multiavchd menu messed up
By jaydev2005 in forum Authoring (Blu-ray)Replies: 3Last Post: 21st Jul 2011, 16:23 -
Forum links all messed up
By lordsmurf in forum FeedbackReplies: 4Last Post: 7th Aug 2010, 17:15 -
Messed up finalizing a dvd
By spunon in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2009, 15:06 -
timecode messed up
By snafubaby in forum EditingReplies: 4Last Post: 20th Sep 2007, 06:00 -
Nero messed up again, need an alternative.
By capman21 in forum ComputerReplies: 5Last Post: 12th Jul 2007, 11:19
