Does anyone know who has these in stock? I've checked the usual places and it seems everyone is out. This has happened before; I'm just surprised that these shortages keep happening. If you can suggest an alternative, I'm listening. The Ritek dual sided DVD-R's have worked out quite well though I'd like to see the price below $3 again!
Thanks.
I bought them off of ebay. Haven't gotten around to using them yet.
Have you had good results with them? -
I'm gonna ask a really stupid question about 9.4GB dual sided DVD-Rs...I assume that if I have a flipper movie (such as Gods and Generals), that I can simply backup Side A of G&G, then burn to side A on my blank 9.4; then flip over and backup Side B of G&G to my HD, then burn side B on the other side of blank 9.4??
Is it this easy?
I'm assuming this eliminates the need to shrink and combine and rename VOBs, etc, etc. -
But even if you don't have a dual sided DVD-R, you don't have to shrink, combine, etc...I'm assuming this eliminates the need to shrink and combine and rename VOBs, etc, etc.
You just burn it to two single-sided DVD-Rs... and then you have a nice blank surface on which to write what the disc is (or put a label). -
Jeff--
Thanks for the input...I honestly wasn't even thinking about that at the time, but you're right, that does eliminate my problem.
I was actually just trying to figure out if what I originally said will work. Based on your comments, I guess my original statement was right.
Thanks guys for all of your help. -
Sorry for not replying sooner; was out of town. The Ritek 9.4 GB discs have worked out quite well for me. The compatability is excellent; using them on Sony, Aiwa, and PS2 players.Have you had good results with them?
I have been buying them 25 at a time and average about 1 bad disc per pack. You can usually tell a bad one by just looking at it.
Any other questions, let me know. -
downer,I bought them off of ebay. Haven't gotten around to using them yet.
How did you find them on ebay? There's a ton of 4.7 GB but I couldn't find any 9.4 GB. What search did you use? I don't think "9.4" is valid and I tried "dual". ("ritek dvd-r" was the rest of the search)
thanks,
websta
HD DVD movie availability in New York
By HARRYSPADGE in forum Off topicReplies: 6Last Post: 10th Dec 2008, 15:44 -
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 15:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 21:23 -
Help, my PC can't read miniDVD dual-sided
By ssalim in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Oct 2007, 07:55 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 04:04
