Ok, I've got some films on svcd/vcd. Up to 3 disks per film (some still as bin), i want to put onto to one dvd-r
The problem is I'm getting pissed off at converting each disk/file.
Can i just join them at one and convert![]()
If so how and what with please.![]()
If they have the same specifications. Extract the mpg with isobuster, join in tmpgenc and then convert.
Use VideoEdit COnverter to join the video.
http://www.viscomsoft.com/videoeditconvert.htm -
I had that sync problem w/ a lot of vcd,svcd,cvd. I stopped joining the files so I get for example two tracks on one cd. This might cause a short pause between the tracks, but saves a lot of work and I dont even notice it coz my DVD player dosent wait between the tracks. I think this apply to DVD making also. So maybe you should just use the batch mode if your using TMPGEnc to do your converting.
mpeg-2 is notoriously difficult to join without messing up audio sync.
Join mts video and convert to ts format
By Benkh in forum Video ConversionReplies: 7Last Post: 17th Aug 2010, 07:14 -
Join and Convert VOB FIles
By solai_4 in forum Video ConversionReplies: 3Last Post: 18th Mar 2010, 04:27 -
Join files ts and convert to avi in linux
By mierdatuti in forum Video ConversionReplies: 1Last Post: 19th Jul 2009, 05:26 -
how to convert & join 2 mkv to ts
By elmc in forum Video ConversionReplies: 1Last Post: 20th Aug 2008, 12:31 -
Need to join two videos and then convert
By vkosinets in forum EditingReplies: 1Last Post: 17th Feb 2008, 07:10
