When I try to cut a movie into two, the video stops at certain points and then makes the audio out of sync with the video. A certain movie a try to cut always stops at a certain point. I used virtualdub to do the cutting. How to I fix it?
Hi sorry for late reply
When you find a bad frame, it might not be on a keyframe.
If you look at the icons you will see a yellow key, click this once forward or backwards to move to the nearest keyframe, then mark this at your start or end.
A letter K is displayed on keyframes
missed that, you need the good old "vdub-mp3-freeze.exe" do a search within this forum for more info, if you cant find it drop me an email.
Cutting MTS: splitter problem
By cheerful in forum EditingReplies: 3Last Post: 6th Jun 2012, 19:26 -
subtitle problem after cutting commercial from video
By satish_j in forum SubtitleReplies: 4Last Post: 25th Nov 2010, 00:51 -
Little problem-Cutting Scenes-Ideas?
By n3ur0 in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2010, 08:44 -
problem with cutting AVI in half with VirtualDub.
By eroy in forum EditingReplies: 1Last Post: 27th Dec 2007, 06:53 -
Cutting Out
By OG24 in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2007, 18:55
