Hello 8)
Could someone please tell / show me how to join two MPEG files together with TMPGnc
Thanks for any help![]()
KaNut
The best way to predict the future is to invent it.
Go to File Menu > MPEG Tools,
select 'Merge & Cut' tab.
Good luck,
Jukka -
and for the next steps...
click Add to select the first file, Add to select the second file, etc. etc.
enter an output name for the new (joined) file.
press Run.
if you want to change where in the file the join happens (ie you have extra footage at the beginning or end of the file), after you add the file to the list, double click on the file name and you can set start and end points.
be aware that TMPG can be picky about joining files that it didn't encode, so you may have problems with files encoded with other programs.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
well, I was just anticipating the next question....
- housepig
Housepig Records
out now:
Cheers Jukka and Housepig 8)
Works great
The best way to predict the future is to invent it. -
IMPORTANT: remember to select MPEG-2 for the stream type. If you forget, it produces godawful results.
ALSO IMPORTANT: You should only try to join encoded MPEG-2 clips rather than cut MPEG-2 clips. If you cut an MPEG-2 file using TMPG and then join it with a nother cut MPEG-2 segment, the result will be missing some P frames and you will get a glitch of digital crud in the midst of a scene where you made the cut. I learnt this the hard way. -
I'll remember that spectroelectro 8) All the work has been done with TMPGnc
Joining two AVIs in TMPGEnc Xpress
By jeanpave in forum Video ConversionReplies: 17Last Post: 8th May 2010, 23:16 -
Joining and Chapters
By nomis66 in forum MacReplies: 19Last Post: 17th Jul 2008, 13:18 -
By nomis66 in forum ffmpegX general discussionReplies: 1Last Post: 14th Jul 2008, 19:29 -
joining 2 dvd5
By BPH2002 in forum EditingReplies: 2Last Post: 1st Feb 2008, 13:24 -
Joining
By breeze9 in forum EditingReplies: 2Last Post: 30th Dec 2007, 15:14
