  1. SVCD n00b
    Guest
    n00b question...
    I just d/l'd this app but when I go to convert my SVCDs, they can't find any since they all have the .m2v or .m2p extensions.
    how would I go about fixing this..?
    thanks.
  2. you need to mux those parts to .mpg to run it through svcd2dvdmpg. use tmpgenc to mux (file => mpg tools)
  3. i have this problem too.
    Guest
    Yep, my problem has only just occured since my re format, when i do a demux i then have the audio (no probs) & a .m2v file, which then mucks everything up cos i can use it again in tmpge, it always used to go into just an mpg file but not now,,!,, am i missing a plugin/codec ??
