  1. I'm trying to use DVD2SVCD to encode a .avi to SVCD, I'm using CCE V2.50, and everything is setup as it should be, but it keeps jamming during encoding in random places.
    I'm using a Athlon XP 2600+ Processor with 1.5 gigs of Crucial Ram, can anyone tell me where I'm going wrong ??.
    Dec 2002
    Did you check the AVI for bad frames? Is it's resolution a multiple of 8? Does CCE work on DVD's, just not this AVI? Does DVD2SVCD crash somewhere during the CCe encode of the movie, or the CCE encode of the beginning/ending title images?
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  3. Yes to all your questions about bad frames ect.
    It always jams during the CCE encoding part of the process, and alays in a different place each time.
