  1. Help , why does XP try to dial out whatever i open (folders,progs,control panel,etc) Ive looked in MSCONFIG and there are no progs trying to access the net, I think its an XP update thats done it because i know about 20 people its happening to
    steve
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    That's one of the reasons why I still dual-boot XP and 98se. 98 is conected to the web and XP is not. XP allways has crap running in the background.
    You might want to install ZoneAlarm. It's free and works great. Then the next time XP tries to connect, ZoneAlarm will warn you. It will ask if you want to let it connect, just say no and never ask again.
    Ofcourse you could have a trojan or something.
  3. Hi ,Ido run Zonealarm and Norton firewall and xp firewall all together.Ive now found the culprit ICBar spyware registry key,it manages to bypass all the firewalls deleted it with x-cleaner
    cheers
  4. Always have Ad-aware (downloads.com) on your computer...it works great on destroying spyware/ shiznit like that.
  5. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Ah, but the one advantage of dial-up is if someone does happen to gain access to your computer they're soon going to realize it's going to take them 4 hours to download a picture from your computer so they'll quickly lose interest
    I've never had security issues with XP Pro, but I update weekly, run a full Ad-Aware and Norton scan almost weekly, and then defrag everything on top of it all. Ad-Aware is certainly worthwile. I wish Norton would add a similar program to their suite, like perhaps purchase the company that maintains Ad-Aware. It'd be cool to have everything integrated into one like that as far as system maintenance goes.
  6. I use ad-aware but it didnt find this little b*****d, x-cleaner got it and thats free
  7. I must ammend my findings ,it is actually windows messenger 4.7 thats causing the dial ups. Ill never update again
