I'm using to Vdub to frameserve from an avi but when set it going it just sits there seemingly doing nothing ! I use DVD2AVI to frameserve my VOBs and its gives a running commentary, but vdub just sits there. Does it take hours to serve ?
Its been running for 30 minutes and it tells me -
Non A/V requests 0
number of frames served 0
Audio segments delivered 0
frameclients installed AVIFile only.
Or am i doing something wrong here ?
Frameserving means serving frames for another application. When no other programm opens the 'virtual' file the frameserver just does nothing
Keep on capping it,
I'll keep on downloading it. -
Try opeining the file *.vdr in TMPGEnc and process your required format.
Dominic -
Yeah, but the little window's number are supposed to start changing for VDub.
Or am I just confused here - it's not the end of the earth anyway as I've managed to figure out deinterlacing filter in TMPGenc
Where can I download Frameserve ?
By DuBsTaR in forum Newbie / General discussionsReplies: 19Last Post: 9th Dec 2011, 18:47 -
Can't Frameserve to Tmpgenc
By BonnieW88 in forum Video ConversionReplies: 1Last Post: 30th Aug 2009, 23:40 -
Frameserve from virtualdub to HC
By SatStorm in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 06:24 -
Frameserve on MacOS??
By Maxwellbest in forum MacReplies: 5Last Post: 4th Oct 2008, 16:34 -
How do I DeInterlace and Frameserve?
By rocky12 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jul 2008, 21:50
