Right...bought some of these Bulkpaq Green 2x disks for my Pioneer 104 drive, ive had nothing but coasters when burnin movies.
But strangely anough when burnin a MP3 / Data disk it completes it and plays it in my DVD player, no problem.
When it comes to movies either burnt at 1x or 2x it either fails around 83%~95% or completes but the set top player does not play em!
Used a Datawrite Gold 1x with exactley the same method and it works perfectly!!!
I JUST DONT UNDERSTAND!!!!
Please help me![]()
Thanx (need any info just ask)
Are they polo's or clears? I've found polo's to be fine for movies but clears are only any use for data etc
tobnvodka -
Polo's??!? nice.
If you mean the centre rim, it is the same green as the disk and from underneath it is white.
Q&A about Pioneer BDP-4100
By come_mon in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Jul 2011, 11:38 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 22:29 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20 -
Pioneer 106D & Maxell 8x DVD-R
By piano632 in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd Jun 2007, 18:38
