I want to try my hand at making short films. Nothing on a professional level; I just want to play director/editor/actor and have some fun.
I'm looking for some inexpensive (ie. < $200) software for editing and authoring mpegs.
ULead seems to be a popular vendor of software...would DVD MovieFactory or VideoStudio be more applicable to what I want to do? I want to have total and independant control of the video and audio streams.
Thanks!
I personally like Video Studio. I like how easy it is to edit, convert, author and burn with it. It has a few nice transitions as well.
Hello. -
I recommend VideoStudio.I have ver.6 and it is stable,easy to use and "Smart Render"is a nice feature.If you want alot of effects then you should get Pinnacle Studio,but some people report Studio is buggy and unstable.
I have "VideoStudio SE DVD" ver 6. Is it different from "VideoStudio"?
Dominic -
Ulead VideoStudio 7 is a good choice.
The free trial download is here:
http://www.ulead.com/vs/trial.htm
The "SE" versions usually come with fewer features than the full versions.
Jerry Jones
http://www.jonesgroup.net
Need help on using Corel VideoStudio X2
By natural4862 in forum Video ConversionReplies: 8Last Post: 12th Jun 2011, 05:13 -
VideoStudio PRO X3
By pepegot1 in forum EditingReplies: 0Last Post: 30th Jan 2010, 09:55 -
VideoStudio PRO X3
By pepegot1 in forum EditingReplies: 0Last Post: 27th Jan 2010, 17:20 -
Corel VideoStudio 12
By netmask56 in forum EditingReplies: 4Last Post: 20th Nov 2009, 00:25 -
help with Ulead videoStudio?
By wamit in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2009, 08:27
