hi guys / girls
i have move my 2 pcs into a cabinet and the mouse k/b and monitor leads are not long enough
does any one know of a site that shows you how to extend your cables as i dont really want to buy a load of cables as there are 2 pcs
thanks
Results 1 to 12 of 12
are you talking about wiring your own extension?
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I am indeed
is it as simple as getting hold of a male and female connector and soldering the wires to each pin in turn?
thanks -
That's fine for the keyboard and mouse, but i'd exercise a little more caution with the monitor, make sure they're decent connections.
you should have no probs with those devices, but extending USB ethernet firewire etc is a little trickier. -
For the USB I'd just buy an USB extendor. They are reasonably priced and come in many different lengths.
are you running 2 separate monitors, mice & keyboards with this, or are you using a switchbox?
if you're using a switchbox, you only need one set of extension cables, going from the switchbox common outputs.
personally, I'd just go for a set of extension cables. for the cost of decent parts and the time I would spend with a soldering iron, I'd rather just pick up a set of ready mades.- housepig
Housepig Records
out now:
When i had my computer in a cabinet it tended to overheat a little and the fan would in turn be extremely loud to compensate. Just to let you know.
you could also buy a usb hub for your keyboard/mouse/etc connections (it would work as an extension too).. i would suggest getting an a/c powered usb connection, not a bus powered one..
I have to say this extending your cables by soldering in sections seems to have "bad idea" written all over it.
As flaninacupboard pointed out, the only real cables that this might work OK would be PS2, serial, and parallel cables. Monitor cables are very sensitive to noise as they carry an analog signal (unless is a DVI connector). Soldering points would introduce noise. Not good.
And USB and Firewire cables are high speed which requires more strict impedances and resistances in the cable. Patching would mess these values up, possibly rendering the cable useless.
I would just use a KVM switch. It would give you a few extra feet without the need to buy separate cables."A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
To end this, just go to your local computer store and buy the appropriate extension cables.
What distances are you talking about, 6 feet or 50 feet? If 50, you might have a prob. If 6 or 10, my local Cable Store sells them, KB, Mouse, Monitor.
The prices are in the neighborhood of 6 to 10 bucks each.
If those distances are within your range, post back, I'll give you their phone number, they should be willing to mail them to you. -
Keyboard or mouse extender $45Originally Posted by thereaper
http://www.neutronexpress.com/prod.cfm/141931/BELKIN/F1D087/KEYBOARD_MOUSE_EXTENDER_250
KVM extender $27.99
http://www.neutronexpress.com/prod.cfm/82642/BELKIN/F3X1835-06-GLD/6FT_CABLE_ALL_OMNIVIEW_2_GOLD
USB extender cables $1.65
http://www.compgeeks.com/details.asp?invtid=USB2-10-MA-FA
monitor extender cable $5.95
http://www.save2much.com/buy/search/Belkin_6_VGA_Pro_Series_Monitor_Ext_Cable
more good stuff there also
http://www.save2much.com/buy/search/10ft_HD15_M_F_VGA_Monitor_Extension_Cable
Usb hub $7
http://www.pcmicrostore.com/part-detail.asp?id=407348
or for a $14 option!!!! (2 X $7 for each cable)
http://www.pcmicrostore.com/part-detail.asp?id=409206
PC controlling a cable box (USA time warner cable)
By marcolisi in forum Capturing and VCRReplies: 2Last Post: 4th Aug 2010, 16:24 -
Extending VGA Signals For Video Post Production House
By avsubvert in forum DVB / IPTVReplies: 0Last Post: 27th Nov 2009, 06:47 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21 -
PSU with detachable/modular cable management Vs stable cable(Recommendation
By retroborg in forum ComputerReplies: 3Last Post: 15th Oct 2008, 14:50 -
extending firewire
By marksk918 in forum ComputerReplies: 6Last Post: 6th Feb 2008, 12:57
