whenever i drag a mpg to the compilation window, it would analyze the mpg first before it let me burn, is there any way i can make nero bypass this analyzing thing?
I do not thing it is possible to turn it off, why would you want to ?
Just try unchecking the "Create Standard Compliant CD". Then Nero will do a minimal MPEG1 checking.
Dominic -
because it would be a lot faster to burn a vcd without itOriginally Posted by hardcoreruss
that doesn't work, it still analyze in which appears to be the same amount of time it takes when i had it checked, so no difference, but thx for the responseOriginally Posted by dominic01 -
errrrrrr....
nero analyzes the .mpg file for a reason. you CAN'T bypass it...and you shouldn't want to either.
nero is checking the .mpg file to make sure it's standard (S)VCD.... if it isn't standard, nero will give you range of options (i.e. 1. re-encode to standard - very BAD as nero does a piss-poor job of encoding 2. burn it as non-standard, compliant)
you want nero to make sure its standard and burn it as standard because standard (S)VCD have the highest dvd player compatibility. it only takes a couple min. to analyze....have patience.
Burning DVD+R with Nero 7
By solarblast in forum Authoring (DVD)Replies: 6Last Post: 24th Aug 2010, 06:17 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Nero 7.7.5.1 start burning at 1x!?
By arminio in forum Authoring (DVD)Replies: 23Last Post: 5th Jan 2009, 06:50 -
Nero only burning at 1x...?
By VEBouto in forum Newbie / General discussionsReplies: 2Last Post: 20th Jun 2008, 23:04 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 09:35
