I am using Tmp to encode A XviD to Mpeg and I keep getting this message everytime I start encoding, try to get the project wizard or try to open something to encode.
Write error occured at address 77F8336F of module 'ntdll.dll' with 00000000
I tried Un+Reinstall and everything I even tried getting many different versions but I am still getting that stupid erroe message.![]()
Results 1 to 15 of 15
Strange ! I've just started getting this as well, TMPGenc worked fine on saturday. Loaded it up yesterday and then loads of problems.
Whats odd is I havn't installed / removed anything, its the latest version which I've been playing with for a while, so it makes no sense.
I've tried the same as you, ie uninstalling, reinstalling etc.
It doesn't matter what I try to do, I just keep getting the same error !
clanger this started to happen to me yesterday too, maybe someone or pegasys inc. sent out some type of virus to attack tmp or something.
What files are causing the error, are they new ?, have your tried it with a file that you have converted in the past, do you still get the error messages ?
Nope, no new files !
It loads ok, then as soon as you open a requester to load a file it gives the error message, then repeatedly throws it up whenever you try to do anything !
I'll have a play again tonight when I'm home from work to see if I can get to the bottom of it..... -
I currently have this problem in Win2K pro with a certain avi file! Please help!
Spooky, this has just started to happen with me too. I think it's certain xvid files that cause it. -
if you are using windows xp, you can use "System Restore"
and roll back your computer to date where everything worked.
just make sure to create a restore point of today, so you can allways roll back to what you have now.HELL AINT A BAD PLACE TO BE -
I started getting this error message also but now (i'm in xp) i don't even get that, tmpgenc just disapears when i try to do anything at all inside the program. I feel that it is the ntdll.dll this started happening after a microsoft update, I downloaded the updates restarted my computer and bam, tmpgenc stopped working lets all sue microsoft.
To fix this problem in WinXP download and install this patch
http://microsoft.com/downloads/details. ... laylang=en
or do a scan disk on your drive and fix any errors it might ave #
thank you -
I had this yesterday after trying to convert an XVid, I thought it was because I uninstalled MainConcept. I tried everything, system restore, reinstalling MainConcept, even considered XP SP1a (because of the ntdll.dll file) but in the end I fixed it by increasing the priority of the 'DirectShow Multimedia File Reader' to higher than everything else. Restart windows and et volia!
Good luck
Jukka -
Sigh, no one searched? This will be the 7th time i've typed this.
1) Reboot
2) Uninstall TMPG
3) Reboot
4) Delete TMPG folder
5) Re-install TMPG
6) Reboot
7) Enjoy
This happens periodically, but a fresh install generally fixes it. As to the problem? Who knows, but for it to 'suddenly start' you have to had to do 'something'. Patch, virus update something. Generally it's installing some software.
I'll tell you this: ntdll.dll is not unique to TMPG, it's alive and well in other applications, and it's not remotely related to encoding video either! Welcome to the proverbial 'DLL HELL'.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I have the same problem. I think it has nothing to do with the program cause it only happens to certain files. I think its a codec issue. We dont have all codec for certain movies. Tell me what u think about that
Tried uninstqalling and thinstalling as posted but to no avail!
I'm encoding to Panasonic Mpg 1 instead.
What can I use as an alternative to split?
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
Error message in TMPGEnc 3 with Divx Authoring...
By blasedeviant in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2008, 13:29 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
