I used DVD Shrink 2.3 to rip a movie, and now I've got the vob files for it. The audio is ac3 and I usually use MovieFactory2 (because of the ease of making menus, haven't found anything better for that) but it won't accept it. I reeaally don't want to convert out of ac3. Is there a workaround I can use or perhaps another program that'll accept the vob files and let me go in and create a decent looking menu for them? Might be newbie-ish, not sure. If there is already a thread for something similar to this, I appologize.
Results 1 to 10 of 10
Ulead DVD Workshop does, but it's not cheap. Do you need menu's? why not just burn the files DVDshrink gives you?
If I can get decent menus then I'd much prefer to have them. I was looking through things on Workshop but I didn't see how you'd insert VOB files into it. Is there a guide or something?
I've never done this, but I think all you do is click on the add video button and browse to the vob file set. IF that doesn't work you may have to convert the vobs to and mpeg file. I'm pretty sure it will accept the vob's though...
The best (and cheapest) DVD authoring program will accept those AC3s just fine.
DVDLab -- there's a fully functioning 30 day free trial, and I'm betting you'll never use anything else after you've tried it."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
Hi, I'm pretty sure I read in the forums that you CAN import AC3 into MF2 (even though it complains). I believe if you set it to not reencode compiant mpeg2 files it will accept AC3.
Hope this helps.
Luap -
I could suggest to use TMPGEnc DVD Author. It accepts mpeg, mpv and vobs files and you can create fairly decent menus. Its not top notch menus but it works pretty fine. It does accept AC3 audio. BTW it is very simple to use.
Where ever you go... there you are...in dvdland -
Another vote for DVDLab. It's only a little more expensive than the TMPGEnc authoring app but massively better.
no authoring programs will accept my avi files
By jsdspif in forum Authoring (DVD)Replies: 11Last Post: 16th Dec 2011, 14:44 -
Retail vs OEM
By bryankendall in forum ComputerReplies: 5Last Post: 3rd Dec 2009, 11:32 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 16:51 -
Some DVD authoring programs will not accept CCE encoded mpeg2 files
By ettin in forum Authoring (DVD)Replies: 8Last Post: 18th Jun 2008, 14:57 -
Retail CD Packaging
By Rich86 in forum Off topicReplies: 0Last Post: 3rd Oct 2007, 19:44
