  1. Member Beautiful Alone's Avatar
    Jul 2002
    Shrinked my movie, then use COPYtoDVD to write the disc..Is there any way to name the title of the movie instead of the default title?
  2. Member Beautiful Alone's Avatar
    Jul 2002
    anyone?
  3. autoshrink can do this...allows you to set whatever volume label you wish.
  4. Try "Options -> Properties" then "Label" tab
    select "Prompt to edit the label", and voila!
  5. Member Beautiful Alone's Avatar
    Jul 2002
    what is Autoshrink..is it same as DVDshrink?
  6. Member Beautiful Alone's Avatar
    Jul 2002
    what program are you referring to?
  7. My sole process for copies is by using DVDshrink and Copy2DVD. Once I select which drive to burn with in Copy2DVD, it automatically pops up a dialog box that asks me for the label. This happens every time and has never failed. Do you get the box, at least?
    Oh, just noticed that in the properties settings, under the label tab, I have selected "Prompt to edit the label". Have you got this selected. The only other option it gives is to auto-assign one. Perhaps this is your problem.
    *Another edit* Just noticed da_playa just said that same thing! haha He was referring to Copy2DVD.
