Has anyone had this problem? DVD plays on pc only. Had alot of luck till the last few updates, re-read guides to see if i missed something but no luck...I'm converting bins using the + version, making 2 movies into 2 vts.. Thx
Results 1 to 10 of 10
Not personally things still work OK.
Have you changed anything else apart from updating svcd2dvd ?
Could be many things, Media not supported by dvd player. -
did you check the dvd players (brown button on the left) if you browsers plays vcd-dvds or svcd-dvd and if it supports dvd+/-r(w)? If one of your anwsers to these questions is no then you can stop trying cause it will never work with any program.
Greatings,
Yf -
Guest
Thx iooi, haven't chg'd a thing and media (DVD-RW) played on same players before...And thx also to yf2001usa but i'm not the beginner u might think, players were bought because they worked.... Just damn funny that they ALL work with powerDVD???? Hope someone else can share some ideas..
You say you are using dvd-RW is this a new disk or one you have been using for a while, as i wonder if its getting past its best ? Never used them myself.
When you say play Ok on the computer do you mean playing the files from your hard drive before burning or reading the files off the disk ? -
Thx iooi
Yes the DVD-RW are new, maybe 8 burns now on it and they worked before..
And i meant the burned DVD's (via COPY2DVD) play on pc. Sorry for not making that point..
Anybody have any ideas? I'm good and lost now... -
svcd2dvdGuest
the problem is players not playing svcd's. on some of the players i have the screen goes black but sound can be heard. the trick i use on the bush player is skip forward, the skip back then fast forward to the start on the film, works for me any way.
Thx svcd2dvd
I get NO sound, just a long reading period which ends up with disk being ejected.... but reads and plays on pc.... -
I would be tempted to use just a dvd-r instead of a -rw to see if that makes a diffrence.
Sounds like dvd player is having a problem reading the disks. -
finally fixed problem, it was copytoDVD. The updaate didn't install properly. The re-install was the fix here and thx to all who tried to help here....mark
DVD plays on only 1 out of 3 players
By mblaine in forum Video ConversionReplies: 9Last Post: 18th Jul 2010, 02:43 -
DVD plays in LG but not in Panasonic
By dexter30 in forum DVD RippingReplies: 4Last Post: 23rd Feb 2010, 22:26 -
looking for a DVD player that plays it all
By gameroftheuk in forum Newbie / General discussionsReplies: 1Last Post: 6th Aug 2008, 23:45 -
It plays OK on the PC but not the DVD?
By thief_ in forum DVD RippingReplies: 4Last Post: 12th Jun 2008, 05:52 -
plays cd and not dvd
By london053 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 9th Nov 2007, 08:26
