i was wondering if someone could tell me how to select multiple items on the menu so i can drag them all at once. for some reason i can't figure it out.
thanks in advance.
Results 1 to 11 of 11
in the program when you create a new menu and you add some buttons and some text i want to be able to select a bunch of things at once and drag them around. i tried holding down the ctrl button no luck, and the shift button, no luck.
He probably wants to get the items all lined up relative to each other and then position the whole group. I'm not sure if there is a grouping command but I'll poke around and see what I find.
Howard -
yes basically thats what i want to do.
any help would be appreciated. for some reason i can't figure it out!! -
I looked around and thought I found an answer. There is a group hotspot option but that is for making multiple buttons associate with the same option I think. So, that's no help.
Howard -
What version of DVD-Lab are you running? Being able to select multiple items is either a function of 1.2.2b or 1.2.3(not yet released).
Is there any way to make a new "menu template"...???
Since each menu item needs to be linked with somthing, thats probably why you can't just "drag and drop"... -
I am running version 1.1.
I will try and upgrade and see what happens.
Thanks. -
the new version 1.2.2b worked like a charm. you just hold shift and select as many items as you want.
thanks for the help. -
unfortunately now i am having a compiling issue. anyone run across this error: "an attempt was made to access an unamed file past its end"
i get this when i try to compile a project. there are a few different switches in this new version but i don't think they are the issue
Any help would be much appreciated again.
Thanks.
DVD Lab question
By sumeshkri in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2008, 22:32 -
DVD Lab PRO2 question
By mvp in forum Authoring (DVD)Replies: 9Last Post: 20th Apr 2008, 21:28 -
Question for those that use DVD-Lab Pro
By PharmBoy in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2008, 23:26 -
dvd lab question
By sumeshkri in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2008, 23:44 -
DVD Lab question
By rizay in forum ComputerReplies: 7Last Post: 7th Dec 2007, 20:13
