  1. Anyone know a lot about the stream type setting in the TMPGEnc?
    If I am making a xvcd with higher bite-rate than standard, say around 1500 CBR, should I still select mpeg-1 video stream not (non-standard)? Any noticeable problem with selecting the ‘wrong’ stream type?
    And what exactly is the mpeg-1 system stream?
    also can anyone drop a link for a guide about using CCE as standalone to encode? DVD2SVCD crashes my system.
    thanks.
  2. since your xVCD is already non-compliant, try to use VBR, instead of CBR, because VBR has a much better bitrate allocation...especially when you use low bitrates (< 2 mbit/s)
