G'day, just purchased a pioneer DVRA06 burner, which came with Nero, Nero express, Mediastudio etc. My problem is that it won't install nero. It installs mediastudio ok, but then when nero comes to be installed an error message comes up and it stops installing. Then when I try to open something like videostudio5 which I have had installed for a while, it comes up with error in ffvfw.dll, close your computer and start again. It also happens with MediaStudio. None of my other burning programs support the pioneer drive. If anybody can help, it would be much appreciated.
Hmm maybe try running "ForceASPI" from the tools section , reboot then try installing the programs.
I just found what was causing it- there is actually a program on my programs list called "FFVFW". I don't know what it does but I uninstalled it and all the programs seem to open now.
Software not installing in English
By beavereater in forum ComputerReplies: 3Last Post: 2nd Feb 2012, 09:48 -
VBScript runtime error when installing Perrla software
By budz in forum ComputerReplies: 7Last Post: 27th Aug 2010, 02:53 -
problems installing add'l software for ffmpegX: mencoder
By Tomtom2011 in forum ffmpegX general discussionReplies: 2Last Post: 2nd Apr 2010, 17:47 -
Installing software suites on external hdd's, pros/cons ? ... [SUCCESS]
By vhelp in forum ComputerReplies: 8Last Post: 6th Dec 2009, 22:25 -
Question why un-installing 1 software knocked out 3 other softwares
By jimdagys in forum ComputerReplies: 6Last Post: 25th Sep 2009, 21:50
