Has anyone experimented with removing this file? Does just the name 'archive.txt' have to be there or must the file have something in it?
I understand that other burning software doesn't require this file at all ( naturally) but how do we use the DVD X Copy without it?
I was hoping someone had a patch for this so it isn't needed at all.
Thanks again.
J T
Doesn't that file just tell dvdxcopy that the dvd is a copy made by dvdxcopy so that it won't copy a copy? You can either delete the file before dvdxcopy burns it or if you're going to make a copy of a copy then you don't even need to use dvdxcopy, just rip it/copy it to your hard drive and burn it or disc-to-disc burn as the copy protection will have been removed already.
HTH -
Hi Yall,
I get this msg. before DXCX starts ripping the movie to my HDD.
What can I do to still get the rip on my HDD without this Archive.txt?
DVD Shrink also does not let me rip it to my HDD, half way trough the process I get an error.Greets, Mysterio
.mpg.txt help
By Draconis in forum Newbie / General discussionsReplies: 3Last Post: 6th Mar 2011, 00:05 -
How do i burn a .txt file to CD??
By Reprobate in forum Newbie / General discussionsReplies: 6Last Post: 31st Jul 2008, 15:09 -
.txt file to .sup format
By pzoggy7 in forum SubtitleReplies: 5Last Post: 1st Jul 2008, 18:56 -
Replacing .txt subtitles
By kpic in forum SubtitleReplies: 6Last Post: 20th Feb 2008, 08:11 -
How do I use subtitles with .txt suffix?
By akulier in forum ffmpegX general discussionReplies: 3Last Post: 19th Feb 2008, 19:13
