  1. i see lot of movies with fps 23.xxx and 29.xxx
    i guess for a pall svcd we need 25.xxx so is it bad to create a svcd (pal) with the none standard fps or does it depend on your player if it will play on my tv ? or doe i have to reencode first the avi to 25.xxx ?
    thanks
    MO, US
    Those are NTSC frame rates, right.
    From what I've seen and heard, most European PAL players can handle NTSC, though some have problems with the FILM (23.976fps) rate. There's a decent chance that it'll work fine if you just create a standard NTSC SVCD (480x480, 23.97fps or 29.97fps).
  3. thanks a lot ............
  4. 23.976 fps + 3:2 pulldown
