So far all the good ones I've found are Trial or Shareware. I found one decent one called PopThis but it only cuts the ads in half pretty much Does anyone know of any freeware that will kill most popups? If not freeware something in the $10-$15 price range would also be acceptable. I just want to see what my options are before I go and pay for software when there might be an alternative thats free that works just as well, if not better and ends up costing me nothing. Thanks in advance.
Rick
Results 1 to 9 of 9
I'm using http://toolbar.google.com/index-beta.php , free and works pretty good. Or else you can always try another browser like Opera or Mozilla firebird with built-in popupkillers.
I'm using pop-up stopper free edition. You can download it at the following link....works pretty great.
www.panicware.com -
You could try this browser called MyIE2, its completely free and has ad blocking in it, i very rarely see ads while browsing now.
Its an addon to your existing IE6 browser and very small and highly configurable than IE6 is, try it and see, i like it a lot and dont use IE6 anymore.
In fact you ALL should use it
By the way theres no spyware imbedded in it or anything.
http://www.myie2.com/html_en/home.htm -
if none of the above works, try GUARDWALL AD BLOCKER. thats what i use.
www.guardwall.com
* it only works against ads made by WINDOWS MESSENGER -
Use Mozilla. I've been using it about 8 months and have yet to see a pop-up.
You'll have to disable pop-ups, the default is to see them.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Originally Posted by fartt
Originally Posted by Baldrick -
Originally Posted by pyrate83
I give 2 thumbs up to mozilla. Works like a charm and gets it right 99.9% of the time, while still letting through those popups that are parts of a site ( not ads ).
It really is quite slick.
Searching for software used in conversion
By Mildragon in forum Video ConversionReplies: 0Last Post: 8th Oct 2011, 15:51 -
Searching for a synchronizing and video/audio editing software
By Raziel in forum EditingReplies: 4Last Post: 2nd Jul 2011, 11:36 -
Fake malware popup creators caught
By redwudz in forum Off topicReplies: 4Last Post: 30th Jun 2011, 20:57 -
Finding The Origin Of A Popup
By hech54 in forum ComputerReplies: 5Last Post: 27th Jun 2011, 10:40 -
SEARCHING: DVD Software WITHOUT re-encoding MPEGs
By jouse. in forum Authoring (DVD)Replies: 1Last Post: 27th Dec 2010, 04:57
